creo simulate save error
hi
   I am getting a model save error while i am saving the simulate model. any solutions
2-Explorer
I found a similar case in our internal database: The model had been sent to PTC Technical Support for investigation and R&D found out that the model had some data corruption, that needed to be fixed in the model file.
Unfortunately the cause for the data corruption never could be found.
So I recommend to either:
  • Start with an older version that does not have the issue
  • Send the model to PTC TS to get it fixed
The error will come up if you use "SAVE AS" in the Simulation environment.
To find out what case the error will be almost impossible.
Use a older version like the other guys recommended.
Take care!
Bogdan
