Feb 24, 2012 6:51 PM UTC
Creo Startup Script - m030
I just tested out m030 and indeed PTC fixed the problem of a process named creoagent being left hanging around after exiting Creo Parametric. In fact that process doesn't even startup anymore.
So if you are running on m030, you can eliminate the first line of the startup script below.
David Haigh
