Creo Version In Parameter
Does anyone know of a way to automatically show the Creo version (3, 4, 5, 6, 7,...) as a parameter?
We implemented the values in param values list, but that is a manual step for the users to change when we go to a new version. We also have it set in our start parts as well as our Windchill templates, but that is a change we will have to do every time we go to a new version.
We are trying to be in compliance to ASME Y14.47 and  14.41
Mahesh_Sharma
22-Sapphire I
Hi @BenLoosli
Set the config MC_GET_VERSION_FROM_META_DATA YN Y in config_init.mc and test the issue. After setting this I am getting the values correctly.
Thanks.
tbraxton
I am pretty sure you will have to use one of the API programming tools (toolkit, Jlink etc.) to automate this. Unless it has been added in Creo 7+ an internal parameter accessible by the UI for the software version has not been available previously.
llie17-PeridotAuthor
I even tried this PTC article without an success in Creo 7.0.4.0
https://www.ptc.com/en/support/article/CS352759
How to create a parameter with value as result of check "PRO_VERSION" in ModelCHECK
I guess it is time to open a PTC case.
Mahesh_Sharma
22-Sapphire I
Hi @llie
TO make it working, ADD_CHK_PARAM in appropriate check file needs to set as Y and in respective start file add PRT_ADD_CHK_PARAM VERSION PRO_VERSION
