Creo will not load Custom Interface File (creo_parametric_customization.ui)
- March 13, 2018
- 4 replies
- 3521 views
I recently had a new OS installed on my machine. Prior to this, I backed up all of my Creo configuration files so that I could later import them as always. After installing Creo 4.0 M030, I simply cannot get my custom user interface file to load. I can successfully load other users' .ui file, but for some reason Creo will not acknowledge my own personal *.ui file. I don't know why my *.ui file would be corrupt if it was working for me prior to the OS installation.
Note: Configuration "load_ui_customization_run_dir" is set to "yes."
