Mar 21, 2016 3:08 PM UTC
Creo will not open
I am running Windows 10 and have Creo 2.0 installed on my computer and it will not open. I run it, I run it on administrator, but nothing happens. The cursor "thinks" and then nothing. I also try to open ModelCHECK, Structure, and Thermal with nothing. When I open Structure, it does tell me there is an Unknown licensing error 26. This has been going on for the past several weeks, usually after I restart my computer. After about a day after the restart, Creo will open again. What is the problem here? I am losing valuable time.
Mar 21, 2016 4:48 PM UTC
Commercial or student version of Creo2?
Commercial version of Creo 2, build 190 and higher are certified for Windows 10.
Not sure of the Windows 10 support for the student version, contact PTC academic support.
amoreira1-VisitorAuthor
Mar 21, 2016 6:36 PM UTC
Commercial.
Mar 21, 2016 6:55 PM UTC
Then I would guess you need to download and install m190 or higher and try it again.
StephenW
Mar 22, 2016 2:42 PM UTC
I would suggest you contact Tech Support. Call them directly.
Technical Support
800-477-6435
