May 18, 2015 2:05 AM UTC
Creo won't run from shortcut
I've been messing with windows' environment variables.
Don't know what I've changed, but now Creo will no longer start via desktop shortcut.
I can copy the path from this shortcut and put on a CMD prompt (Start+R > cmd). Creo will run fine with this method (proving it's integrity).
How to fix it ?
2-Explorer
May 18, 2015 2:28 AM UTC
Maybe the 'start in' is broken or the permissions on the shortcut have changed? Dunno for sure, but something to eliminate.
lsilva1-VisitorAuthor
May 18, 2015 2:32 AM UTC
I've deleted and recreated the shortcut. First time without, then with the Start in option. Did Not work.
The program won't run from the executable straight either
Creo's startup is a whole scripting system.
How it works, I don't know. But it depends on the environment variables. That was the only thing I've changed.
May 18, 2015 5:16 AM UTC
Lucas,
create a shortcut to parametric.exe file and give it a try. Set Start in directory to %TEMP%
Martin Hanak
