Oct 4, 2014 9:53 AM UTC
Creo2.0 Student Install Issues
While i was attempting to install Creo2.0 on my computer it froze and i had to restart it when the Creo Common Files were only about 10% fully installed. I can now no longer continue to install the remainder of the common files which is also cause me to not be able to run any of the installed parametric, direct etc.
I have tried searching for ways to completely remove all the files associated with Creo so that I can try to reinstall. I have also tried two system restores on my computer to no avail.
Hoping that someone can help me with a solution as I have assignments that need to be finished asap.
Oct 4, 2014 11:10 AM UTC
Kyle,
simply delete Creo installation directory.
Martin Hanak
Kyle,
Martin Hanak
Oct 5, 2014 11:18 PM UTC
Thanks Martin, but how can i do that exactly? I'm not very computer savvy.
Oct 6, 2014 3:46 AM UTC
After a bit of playing around and some patience I've finally managed to get Parametric up and running. Thank you
