Nov 20, 2012 1:33 AM UTC
Creo2 M020 Freezing
Our use's Creo2 M020 cache are getting corrupted for no reason has anyone had this as a reoccurring issue.
Take care,
JEREMY HANDLER
Mechanical Engineer
1+760-591-7318
[Description: Grren] Consider the environment. Consider the impacts.
    Nov 20, 2012 3:54 PM UTC
    Are you running this with Windchill? Is your cache set to the same location as Wildfire?
    Andy Hermanson
    Engineering Design Applications
    tel 605.275.1040 x51114 mobile 605.310.8168
    website www.daktronics.com
    Nov 20, 2012 8:45 PM UTC
    Hello all,
    My current machine T3500 precision Dell has started random unexplained shut down and restarts. Dell has offered to replace my workstation with one as specified below. Can anyone tell me if this will work as well or better than my current machine? We are running WF3 M100.
    Thanks!
    QUADRO 2000
    GPU Specs:
    NVIDIA Quadro GPU
    Quadro 2000
    CUDA Cores
    192
    Form Factor
    4.376" H x 7" L Single Slot
    GPU Memory Specs:
    Total Frame Buffer
    1 GB GDDR5
    Memory Interface
    128-bit
    Memory Bandwidth (GB/sec)
    41.6 GB/s
    Display Support:
    Dual Link DVI-I
    1
    DisplayPort
    2
    # of Digital Outputs
    3 ( 2 out of 3 active at a time )
    # of Analog Outputs
    1
    Maximum Display Resolution Digital @ 60Hz
    2560x1600
    3D Vision/3D Vision Pro
    [yes]
    Feature Support:
    Shader Model
    5.0
    OpenGL
    4.3
    Microsoft DirectX
    11
    SLI Multi-OS Technology
    [yes]
    NVIDIA CUDA Architecture
    [yes]
    Mosaic Technology¹
    [yes]
    NVIEW Display Management Software
    [yes]
    FSAA (maximum)
    64x
    Audio Support (via DisplayPort)
    [yes]
    Thermal and Power Specs:
    EnergyStar Enabling
    Yes
    Maximum Power Consumption
    62 W
    Relative Performance Score
    23.85
    ¹ Mosaic Technology will be available with upcoming driver release in Winter 2010.
    T3600 Precision
    Processors
    Intel® Xeon® processor E5-1600 or E5-2600 family with up to eight-cores and Intel Advanced Vector Extensions, Intel Trusted Execution Technology, Intel AES New instructions, Optimized Intel Turbo Boost and optional Intel vPro(tm) technology
    Operating Systems
    * Genuine Windows® 7 Ultimate 32-Bit; Genuine Windows® 7 Ultimate 64-Bit
    * Genuine Windows® 7 Professional 32-Bit; Genuine Windows® 7 Professional 64-Bit
    * Red Hat® Enterprise Linux® WS v.6.1 EM64T (Also certified to run Red Hat Enterprise Linux Version 5.7 64-Bit)
    Chipset
    Intel® C600 series chipset
    Memory2, 4
    Quad channel; Up to 64GB 1600MHz or 1333MHz ECC and non-ECC DDR3 memory; 4 DIMM slots
    Graphics4
    Support for two PCI Express® x16 Gen 2 or Gen 3 graphics cards up to 300W (total for graphics):
    High End 3D Mid-range 3D Entry 3D Professional 2D (not ISV certified) NVIDIA® Quadro® 6000 AMD FirePro(tm) V7900 AMD FirePro V4900 AMD FirePro 2270 NVIDIA Quadro 50005 AMD FirePro V5900 NVIDIA Quadro 600 NVIDIA Quadro NVS(tm) 300 NVIDIA Quadro 4000 NVIDIA Quadro 2000
    GPU
    NVIDIA Tesla® C2075 GPGPU - Supports Nvidia Maximus(tm) technology
    Storage Options6
    Up to two 3.5" or four 2.5" internal SATA, SAS or SSD drives.
    SATA 7200RPM SAS 10K RPM SAS 15K RPM SSD Up to 3.0TB Up to 900GB 146GB 256GB
    Storage Controller Options
