2-Explorer
Nov 30, 2012 5:30 PM UTC
curves not visible
I have never seen this before. A new user running WF5 loaded an old config
file that has been floating around the office since before WF - I can tell
from some of the settings and some of the mapkey syntaxes. Upon doing so,
he lost all ability to see any datum curve. They highlight when selected
from the tree. They redefine properly and are visible in sketcher. They
cannot be seen on the screen. Layers are fine, features are set to visible.
I just cannot figure it out. Allegedly, if he runs without this config, he
can see the curves as expected. The config file is over 100k and has
hundreds of lines. There are some mapkeys and settings in there that he
supposedly needs. I instructed him on building his own config using
copy/paste, etc. But I am still wondering what config setting would stop
curve visibility.
Any ideas for this or for troubleshooting this?
Thanks a lot.
-Nate
Nov 30, 2012 5:49 PM UTC
Nathan,
In earlier versions of Pro, the option used to be:
datum_display
datum_point_tag_display
Check to see if he has those set to "no"
In Wildfire 5.0, you can set the following options to yes.
display_planes yes
display_plane_tags yes
Hope this helps!
Dec 3, 2012 8:15 AM UTC
If they a only missing in shaded mode this option could be the problem:
shade_with
curves*, no
Displays datum curves on shaded objects.
Best Regards,
Bjarne Frandsen
