May 10, 2022 8:01 PM UTC
Custom Bill of Materials in Assembly Mode
Hi Folks,
Is there a way to customize/tailor the Bill of Materials report in assembly mode so that the headers can be specified as parameters?  For example, instead of the default column header 'Name' I would like it to be 'Title'.  I would also like to create additional column headers. Thank you.
May 10, 2022 8:38 PM UTC
wbottis14-AlexandriteAuthor
May 10, 2022 8:45 PM UTC
Thanks, Ben.  I did see that, but was looking for something for simpler people like me.  I will take another look if this is the best we got.  Thank you.
May 10, 2022 8:57 PM UTC
It looks more complex than it really is. Once you get through the example and see how each level is built it makes more sense.
Are you using Windchill, too? You can also do Structure reports from the assembly detail page and export them to Excel.
May 11, 2022 6:58 AM UTC
also consider the creation of temporary drawing containing repeat region table. You can export it to csv file.
