Sep 25, 2014 8:28 PM UTC
Custom Creo Deployment
In my past job, the admin created a script to check and pull the Creo (WF5) and any updates using the shortcut on our desktops. I am in a new job and we have a need to install the latest update to ~100+ folks at my location. I have asked the IT here to write a script to do basically the same. I was told they do not have the resources here so I'm on my own.
With that being said, is there a tool or software I can use to basically do the same without having IT to write a script?
* Shortcut that user will select to run Creo
* if there's an update copy the latest update and override the config.sup/pro etc
Thank you all in advance!
Calvin
avillanueva
23-Emerald II
Sep 25, 2014 8:32 PM UTC
How is your system access? Do users have admin access or rights to write to local HD? That depends. It should be possible to simply copy the installation to a local HD. We opted for installation scripts that does a silent install. There is a documented method of running and install that creates an XML script that users can run and its silent.
After that, we run a script that copies down configs and settings before launching Creo. It's a hook that you can use to make sure all systems are the same. Just have to copy to user's desktop.
Sep 25, 2014 8:51 PM UTC
SCCM(Windows tools) should do the trick and should definitely be something IT is familiar with on some level.
