datum name text size
Since I've changed my screen for a bigger one (with a higher resolutions) datum names are displayed very big.
for example DTM1.
So it's hard to see the model when I have several Datum planes and axis.
Is it possible to set this text size in config.pro ?
Mahesh_Sharma
22-Sapphire I
November 28, 2017
Try using config option  text_height_factor with value as 80 or more. Restart Creo after adding config option.
18-Opal
November 27, 2017
Hi Dominique,
I don't think there is a way to control the text height of the datum tags.  It should adjust according to the resolution of your machine.
Can you try changing the resolution, to see the behavior of the text size, after the change?
Amit
Mahesh_Sharma
22-Sapphire I
November 28, 2017
Thanks, KSM.
It works fine and change my CAD life !
Stange to see that increasing the value decrease the font size.
However, Text_height_factor, is realy better at value of 80.
It's even better @ 120 for me. 😉
