Mar 15, 2011 6:48 PM UTC
def_layer
WF4 M080
Is there a way to get layers created by the config.pro 'def_layer'
command into parts that were created prior to that command being
implemented?
I've tried a simple regen, a forced regen via the model player and
dragging the insert bar to the top of the tree and back.  None caused
the layers to be created.  The only thing that seems to work is the
creation of a feature.  Surely there has to be a way to do this.
Doug Schaefer
Mar 15, 2011 7:58 PM UTC
The only way I know is to create the layer requirements under
Modelcheck.
Running Modelcheck will prompt you to add the layers, and then will
prompt you to put the features on said layers, but the rules will not
exist so layers will not automatically add new features.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Mar 16, 2011 12:28 PM UTC
To check automatically for the standard list of layers, STARTCHECK needs to be enabled. If a feature does not exist, ModelCHECK will not report the layer missing unless REPT_LAYR_ALWAYS is set to Y. Supposedly, if this is set, ModelUPDATE will automatically add missing layers.
In Reply to Doug Schaefer:
WF4 M080
implemented?
Doug Schaefer
Senior Project Engineer, Mechanical
www.design-central.com <
Tel +1 614 890 0202
Fax +1 614 890 5880
Design Central designet
6464 Presidential Gateway
Columbus, Ohio 43231
USA
Confidentiality Notice
This is a transmission from Design Central Inc, Columbus, Ohio which may
be privileged and confidential, and thus is protected from disclosure.
This message is NOT intended for transmission to, or receipt by, anyone
other than the named addressee (or a person authorized to receive and
deliver it to the named addressee). If the reader of this message is not
the intended recipient, or an employee or agent responsible for
delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution or copying of this
communication is strictly prohibited. If you have received this e-mail
message in error, kindly accept our apology and please delete it from
your system without copying or forwarding it, and notify the sender of
the error by reply e-mail or by calling 614.890.0202 (collect).
