3-Newcomer
DEFAULT_CALLOUT_FORMAT_DATA
I am using Creo Parametric Release 10.0 and Datecode10.0.1.0
Tapered threads do not show up in the dialog box once I add a DEFAULT_CALLOUT_FORMAT_DATA to the hol.-file.
The hol.-file has previously worked in Creo 8
    you have to add STRAIGHT_DRILLED_DEPTH token into DEFAULT_CALLOUT_FORMAT_DATA section.
    https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/part_modeling/part_modeling/Thread_Notes.html
    3-Newcomer
    I have attached the hol.-file.
    Does anybody know why the thread does not show up in the dialog box once I add a DEFAULT_CALLOUT_FORMAT_DATA to the hol.-file?
    Everything has been done according to:
    Formatting Thread Notes (ptc.com)
    Thanks in advance.
    Mahesh_Sharma
    22-Sapphire I
    Hello @TA_10763298
    Did you get a chance to test the suggestion?
    3-Newcomer
    Yes, it works well with my file now.
    Thank you for the help!
