Sep 10, 2012 3:47 PM UTC
Default template name and location
I am trying to find the "default" template. I looked for the search path for it in config pro but I dont see it. I would like to find it and remove "MODELED_BY" parameter.
cncwhiz1-VisitorAuthor
Sep 10, 2012 4:07 PM UTC
We used to use start_part as well as start_asm. We no longer use them.
_____
Sep 10, 2012 5:39 PM UTC
<creo loadpoint=">\Creo 2.0\Common Files\M020\creo_standards\templates
Also consider settingyour own default templates (path and filename)in config.pro. Just find "template" in the option editor.
Stuff modified in the creo loadpoint has a bad habit of being deleted when you upgrade versions or datecodes.
