Jan 17, 2013 3:55 PM UTC
Deprecated ProDevelop function
Wondering if someone can help me out. I am aware that Pro_develop was
removed in Creo 2. I am currently in WF5/Creo E pro, and I'm using
prodb_eval_bend_srf function. There is no equivalent to that function
in my version.
Can someone with the Creo2.0 TK documentation please send me the
function definition for whatever the function is that replaced the
prodb_eval_bend_srf? The equivalents are listed in the
pd_proto_deprecated.h
Thanks a bunch,
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215 or 989.773.7981, ext 12484
Integrity, Commitment to Stakeholders, and Passion for Excellence
Jan 17, 2013 4:10 PM UTC
Mark -
I have Creo 2 M030 installed on my machine. I could not find any reference
to prodb_eval_bend_srf() in pd_proto_deprecated.h or any other .h file in
prodevelop/includes or protoolkit/includes. For sanity's sake, I confirmed
that prodb_eval_bend_srf() is defined in Creo 1 (WF5) M090 in
pd_prototype.h.
Unless somebody else has found it, I think you should contact PTC about
this
function.
|+| M a r k |+|
Mark Stallard
Rapid Response Development
information Solutions
Integrated Defense Systems
Raytheon Company
(business)
+1.339.645.6423
(cell)
+1.617.331.5443
(tie line)
224.6423
235 Presidential Way
Woburn, MA 01801-1060
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
Jan 17, 2013 4:17 PM UTC
Hi Mark,
I didn't find anything matching prodb_eval_bend_srf in Creo 2.
pd_proto_deprecated.h doesn't mention anything.
I also searched for an equivalent function, still didn't get anything
Vinay
msteffke15-MoonstoneAuthor
Jan 17, 2013 4:56 PM UTC
Thanks everyone for that information. That is a cornerstone function
for us. I had looked through the TK release notes for Creo 1 & 2 and
saw no mention of any changes to this function. Disappointing, but in
no way suprising.
Mark Steffke
Jan 17, 2013 8:45 PM UTC
Tech support said this had been reported, however my search this morning
found no such topic. Since my call log my search now reports the issue.
Document Information
Type Article
Date Created 17-Jan-2013 12:31:21 EST
Date Last Updated 17-Jan-2013 12:36:46 EST
Document Details
Title What is the equivalent Pro/Toolkit function for
prodb_eval_bend_srf() in Creo Parametric 2.0
Description
* What is the equivalent Pro/Toolkit function for
* prodb_eval_bend_srf() function was deprecated and never
replaced.
Applies To * Creo Parametric 2.0
* Pro/Toolkit API
* Pro/Develop API
Cause
Resolution
* Reported to R&D as SPR 2163021
* PTC R&D is working on introducing an equivalent new function in
Pro/Toolkit and Creo Object Toolkit for future Creo Parametric releases.
Workaround:
* Use the same Pro/Develop function prodb_eval_bend_srf() in
existing Pro/Toolkit application.
* Please refer to "CS99730:
<">http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS99730>
Mark Steffke
