Difference between Creo Parametric Essentials and Creo Engineer (T1, T2, T3, T4, T5) Packages
Hello All,
Kindly tell me what's the difference between Creo Parametric Essential Packages and new Creo Engineer Packages (pictures attached)? Are these both set of packages valid now and on which purposes/basis or conditions we can classify that whether we need essentials package or engineer package.
Kindly sort this out ASAP.
Thanks...
please ask your PTC VAR.
AfeenA1-VisitorAuthor
We are the PTC VAR.
If you are VAR then ask PTC.
