difference between Student Version and Educational Version
  • January 16, 2016
  • 5 replies
  • 14070 views
The questions like in topic.
On Jan 01 of 2016 my last Student License was finished  - it was M040 64 bit( if I remember well) installed on the WIN 8,1 which was transfered to WIN 10 during  the license period.
Now I have downloaded  the new zip file with M060 64 bit, and it was extracted properly. It is all what I could do. I tried to install license for two hours and still got an error message.
In the end I run with succses setup-schools file. Now I have installed Educational Version.
Am I right and not in conflict with the licence agreement, and with the PTC student account conditions ?
What are my limitations in Educational Version ?
Will I be able to return to the Student License ?
Thanks in advance for answering my questions.
Regards
Ludwika
Best answer by gkoch
Hello Ludwika,
  • If you have used your previous license file to install Creo, I'd suspect it's completely legal and setup-schools.exe probably is the correct tool to install your version.
  • About limitations in functionality between the different Editions, I can't help, as I simply have no knowledge on this. But I am sure they all have the complete modelling functionality available.
  • In any case you should be able to switch between the different Academic Versions (i.e. University Plus Academic Edition, University Student Edition, Schools Edition), because the models are compatible (there is only a limitation with retrieving those models into commercial versions)
Gunter
gkoch2-ExplorerAnswer
2-Explorer
January 21, 2016
Hello Ludwika,
Gunter
Thanks Gunter. Now I am comparing this two versions  and so far I have not encountered differences.
Regards
Ludwika
Extrude features are less
11-Garnet
December 1, 2017
Hi all, I am using creo 4.0 student edition and it can not open excel files in excel analysis. I looked after how to do it in videos and the teacher showed us, but in the school we use educational version. Am i doing something wrong or the student edition can not create excel analysis.Thanks for the help.
