2-Explorer
Different languages for Creo
Hello
Can I have Creo installed on my machine with two different languages in single installation?
If so, How can I set language either from two installed language without doing re installation?
Any idea would be of much help.
Thanking you!
Regards
Ketan
8-Gravel
Our solution is to create a .bat launch shortcut for each different language allready installed and set the LANG option like bellow :
if NOT EXIST C:\Temp (mkdir C:\Temp)
set DEFPRO=\\your.network.adress\
set APPLI_DIR=C:\Program Files\PTC
set LANG=ENGLISH
set TRAIL_DIR=C:\Temp
@echo off
"C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.exe" %*
Normally it's ok.
Best regards
DomenicLaritz
Hello @Ketan_Lalcheta,
if you would also like the Creo language to be changeable during a running session and not just defined during program startup, please vote for my idea of improvement:
"Changing language of user interface during running session"
