Disable Dimensions Preview Creo 3.0
Is there a config.pro option to disable the preview of the dimensions on Creo 3.0? Most of the users find this functionality annoying and not very helpful since sometimes it gets in the way of the other edge you would like to select.
I hope I don't have to create a Product Idea for this.
Thank you.
do you mean dimensioning in Drawing mode ?
MH
jnegrini1-VisitorAuthor
Hi Martin,
Yes, I would like to disable that grey dimension preview that appear every time you select and edge. Could not find anything on config.pro or on PTC support Portal.
Julie
I think dimension preview is a new Creo 3.0 feature, which cannot be disabled. You can confirm this information by contacting PTC Support.
MH
