Disable graphics.....
- September 12, 2014
- 0 replies
- 702 views
I figure the cad list (especially David Haigh if memory serves 😉 would appreciate the test/workaround given to me by PTC TS. And it could be this was a replacement for the deprecated graphics config.pro setting and I missed it......
Please take a look at article
..... I saw in that call, specifically a note saying:
"customer to set -g:win32_gdi syntax at parametric.exe startup to launch Creo in non-graphics mode. Creo launched successfully and customer was able perform operations better than in graphics card mode and saved files successfully."
So I figured it was worth having you try this. The above article has the instructions on how to run in this mode that disables the hardware graphics acceleration.
Thank you,
Brian Krieger
[75th]
Thank you,
Brian Krieger
[75th]
