May 6, 2013 9:38 PM UTC
disable navigation tab/window
If someone knows how to permanently disable the navigation tab or window, so i don't have to close it every time i open a new window; i know i know its only a second and i have a map key to turn it off but still I would be very excited to know how
Thanks!
Joe G
    May 7, 2013 5:16 AM UTC
    Hi Joe,
    I think that you do not like the startup window
    You can set/unset this option: File>Option >> Window Setting // Expand the browser during startup
    Vladimir
    SYNDAKIT15-MoonstoneAuthor
    May 7, 2013 2:29 PM UTC
    May 7, 2013 2:45 PM UTC
    The model tree? Not sure what you are referring to as a Navigation Tab.
    May 7, 2013 7:11 PM UTC
    Hi Joe,
    If you need to switch of this part of window (Model Tree or Layer Tree), you can create the trail file and run it while the Creo Parametric start. I think that is much easy for you use a Mapkey
    Vladimir
    May 8, 2013 4:43 PM UTC
    Palffy- that sounds super cool. I read up on what trail files are but not sure how to create them. do you have a link to an example?
    May 9, 2013 5:29 AM UTC
    Dear Joe,
    I will prepare some short video tutorial for you
    Vladimir
