Jan 7, 2015 3:03 PM UTC
Display an Excel spreadsheet on a drawing
Hello all,
I would like to display an Excel sheet on a Creo drawing. I used the technic explained on this forum, ie Object>Create from file>Select my file>click Ok. But unfortunately it only displays a sort of texte box with the excel filename (image below). If I double click on it, it opens the excel file. But I would like to display the content of the excel file. Is it possible ? Do I have a config problem ?
Jan 7, 2015 3:54 PM UTC
Raphael,
the same result as in the previous discussion ...
I use Creo Parametric 2.0 M070 64-bit English and MS Excel 2010 32-bit Czech. Object>Create from file>Select myexcel.xlsx>click Ok and I can see my Excell sheet inside the drawing. Maybe Office reinstallation removes the problem ...
Martin Hanak
Jan 7, 2015 3:30 PM UTC
Raphael,
what version of Microsoft Office is installed on your PC ?
In 2008 I was able to put Excel sheet into ProE drawing.
I used MS Office 2003 and Pro/ENGINEER Wildfire 3.0.
Martin Hanak
RaphMORIN16-PearlAuthor
Jan 7, 2015 3:36 PM UTC
Martin, I'm using Office 2010 !
Raphael,
Martin Hanak
