Display drawing in CREO Window from Session memory
I tried to display drawing which available in session using following commands,
ProObjectwindowCreate(new_dwg_name,PRO_DRAWING,NULL);
ProMdlDisplay (drawing);
Drawing  displayed in CREO.Window, but hangs the session.
Please suggest me to solve this issue.
In ProObjectwindowCreate function try to replace the NULL variable (last variable) with an integer:
ProObjectwindowCreate(new_dwg_name,PRO_DRAWING,&win_id);
Also I usually call ProVindowCurrentSet and ProWindowActivate after ProMdlDisplay. It should look something like this:
ProMdlNameGet(drawing,new_dwg_name);
ProMdlDisplay(drawing);
ProWindowCurrentSet(win_id);
ProWindowActivate(win_id);
Hello Gabriel,
Your Code works fine. Thank you very much and also thanks for the Setting & Activating the Current window Tips.
