AF_mechdesigner
Does anybody have UDL files for editing Pro/Program and Relations with Notepad++?
does anybody have UDL files for editing Pro/Program and Relations with Notepad++? I've already set the config option "pro_editor_command" to my Notepad++ installation path (to use N++ instead of Notepad.exe) and I was wondering if anybody has already uploaded UDL files somewhere. Thank you in advance.
Old Topic for reference - https://community.ptc.com/t5/System-Administration/Notepad-User-Defined-Language-files-for-Creo-Parametric-and-Pro/m-p/451745#M6999
And thanks to @DomenicLaritz for sharing the UDL files for config and .dtl files!
AF_mechdesigner
I created this Notepad++ UDL file; it's not perfect, but it's an improvement compared to using Notepad.exe in my opinion.
Feel free to improve it or create a new one with clearer syntax highlighting.
The file should be copied in C:\Users\username\AppData\Roaming\Notepad++\userDefineLangs
I found out this topic is already solved here:
https://community.ptc.com/t5/System-Administration/Notepad-User-Defined-Language-files-for-Creo-Parametric-and-Pro/td-p/451745
GitHub links are working and are updated. I use still Creo 7 and there already up to current version 11.
Hope this helps somebody.
I'm sorry, I posted to different TAB. This is different topic, please ignore my first post.
