Does Anyone Have Documentation of System Colors
- 0 replies
- 718 views
- Translate All
The system colors, for example system_geometry_color, can be set via specifications in a file. For example, I use "syscol.scl". To the best of my knowledge, there is no documentation of what parameter names are available for these settings. Equally important, it is not clear what effect setting any of these parameters will have.
I'm wondering if anyone has any documentation of the following:
(1) Parameter names
(2) Screen elements affected by a given parameter
(3) Syntax for the settings file, i.e. what alias_sec_dim_strong_color_to means, the color value ranges, etc.
I had asked this same thing as an Idea for it to be added to the Help documentation. It was pretty much ignored. I naively thought that such things would be documented and available, but that does not appear to be so.
