Mar 11, 2015 12:41 PM UTC
double-click a pkg starts wrong version of Modeling
For my job I have installed several versions of Modeling on my notebook. When I double-click on a .pkg or .bdl-file, it opens Modeling version 17.0,but I would rather like Modeling to open in version 19.0. I have tried several things like changing the default program in Windows, made changes in the regestry, but Modeling keeps starting in version 17.0. I think it is because version 17 was the latest version I have installed.
Reinstalling version 19.0 did solve the issue, but i think that's a rather drastic, time consuming operation. it would be much easier if:
  • an environment variable could be set containing the version that should start. (like for drafting MEPELOOK=2)
  • you could choose in the list 'open with' with what version you want Modeling to start.
Mar 13, 2015 9:00 PM UTC
There is a value in the Registry Editor for HKEY_LOCAL_MACHINE/SOFTWARE/CoCreate/SolidDesginer for: LastInstalledVersion.
You might try just editing that value to the value for version 17 (maybe something like: 17.0.3.30)
Mar 31, 2015 2:14 PM UTC
Check Registry:
HKEY_CLASSES_ROOT\SolidDesigner.Package\shell\open\command
e.g.
D:\Program Files\PTC\Creo Elements\Direct Modeling 17.0 - 17.0.6.2\binx64\SolidDesigner.exe /dde
Hope this helps,
- Max
Jan 8, 2016 10:05 AM UTC
Is this question still open?
