Jul 29, 2016 7:09 AM UTC
Drawing Axis disappears when I make it a datum
When I create a datum plane/axis in Creo 3 the corresponding axis disappears and I end up having to create a new axis in the model so it shows in the drawings.
Is this a config issue?
Aug 2, 2016 8:36 AM UTC
Martin,
This is the common behavior that i have observed in Creo 2 and 3. We usually create a separate datum axis in such cases to use as a GTOL datum, be it a datum plane or axis.
18-Opal
Jul 29, 2016 7:37 PM UTC
Martin,
Please check your layers and see if the datum features are being hidden by default.
Amit
Aug 1, 2016 7:01 AM UTC
Hi Amit,
Thanks for your advice....
I have checked the datum feature in both the model and the drawing and thy are not hidden.
Any other ideas?
Thanks....
Martin.
18-Opal
Jul 29, 2016 8:01 PM UTC
It could be that the axis is being placed on a layer that is turned off...
Hi Mark,
Any other ideas?
Thanks....
Martin.
Aug 1, 2016 10:24 AM UTC
please upload testing data. Use How to Attach a File to a Discussion Reply procedure.
MH
Aug 1, 2016 10:36 AM UTC
Hi martin,
Please find attached the model and drawing.
Martin....
Aug 1, 2016 11:02 AM UTC
Martin,
please can you describe step-by-step procedure "How to reproduce the problem..." ?
MH
