Drawing Checkin; Unassociated Part is Being Checked in Too
Another obscure Creo issue that I will try and describe.  I just attempted checkin of a new drawing.  The assembly was checked in by itself already.  Upon checkin of the drawing, a new part having nothing to do with the drawing is being checked in.  This same part did not "want" to be checked in with the assembly, only the drawing.  Where is this link taking place and how do I break this link?  Thank you.
TomU
More than likely if you view the details page for the drawing and/or the part, you will see a reference from each to the other on the 'Related Objects' tab.
How the link was created is a whole different issue.  Things I normally check:
  • Has the part been added directly to the drawing?  (Look at the drawing's drawing models.)
  • Does the part have any references to the assembly?  (Check the assembly's reference viewer and both object's 'Related objects' tab in the embedded browser.)
  • Is there a relation reference to other parts anywhere?  (Something referencing this object's session ID?)
If the only link is between the part and the drawing, and there are no other links from this part to the assembly or any other parts, then usually I go down the path of backing the drawing up to disk, erasing it from session, removing it from the workspace, removing the offending parts, and then reopening it from disk with the config option "cleanup_drawing_dependencies" set to "YES_CS_NOT_REQUIRED".  This should pop up a box giving you the opportunity to permanently remove this (now missing) reference from the drawing.
Is that part shown on the drawing?
I have attached a test part to a drawing template one time by mistake. Not shown on the drawing, but still loaded with the drawing only.
wbottis14-AlexandriteAuthor
no, the offending part was not added to the drawing independently, I have double-checked.  The only model associated with the drawing is the assembly.
StephenW
If that part is in the assembly that is in the drawing, it will always check in with the drawing.
If you don't want that part to check in, undo the check out.
