Sep 5, 2012 10:05 PM UTC
Drawing Templates? No way to point to different folder?
When you create a new drawing, you get a list of templates that PTC
includes in a local folder.
Is there a config.pro setting to point this somewhere else? Or are we stuck
with putting stuff in the local folder?
If so, that is terrible.
20-Turquoise
Sep 5, 2012 10:08 PM UTC
On 09/05/12 17:05, Michael Gamber wrote:
> When you create a new drawing, you get a list of templates that PTC includes in a local folder.
> Is there a config.pro <">http://config.pro> setting to point this somewhere else? Or are we stuck
pro_format_dir
ie
pro_format_dir         ilcs://server3/Root Folder/library/formats
pro_format_dir         wtpub://WindChill/Libraries/CAD/ProEngineer/formats
pro_format_dir        /some/directory/path
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
Sep 5, 2012 10:09 PM UTC
start_model_dir (config.pro)
20-Turquoise
Sep 5, 2012 10:14 PM UTC
> pro_format_dir
> ie
Oops. I just realized you were asking for templates NOT formats.
I think Antonius has it correct with start_model_dir
> Randy Jones
> 1525 E North St
> PO Box 5060
> email:-
> Phone: 785-823-3276
>    Fax: 785-667-2695
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
Sep 6, 2012 2:28 PM UTC
Start_model_dir points to a folder on disk that contains the start parts and drawing templates.
You can also use Template_drawing to point to a particular drawing template, using full path name, to be used as your default template.
We have it pointing to our C-size part drawing template file.
Thank you,
Ben H. Loosli
USEC, INC.
