Aug 9, 2011 3:50 PM UTC
Easy one? Can I set a default username login for ProE/Intralink?
I found this tip, but it doesn't work on my system?
I have XP 64 bit, WF 4 M160, Intralink 9.1 M050
http://www.proengineertips.com/configuration/tips-how-to-set-the-default-login-name-for-pro-intra-7.html
David T. Francis
Aug 9, 2011 3:52 PM UTC
That tip applies only to Intralink 3.x, not 9.x.
Gerry
In Reply to David Francis:
Aug 9, 2011 4:55 PM UTC
This will suffice for me - and it was pointed out the tip was for 3.x not 9.x Thanks everyone!
David,
For what it’s worth, if you use LDAP to authenticate with IntraLink (8+), you are prompted with a login which allows you to save the username and password. This method also permits the user to have the same username and password for their system login.
Best wishes,
Jered
David T. Francis
David T. Francis
