3-Newcomer
EMX \Using Older Version Settings
We recently upgraded from Creo 8.0.1.0 using EMX 14.0.0.0 to Creo 9.0.1.0 which uses EMX 15.0.0.0.  Creo 9 loads ok and launches EMX 15 BUT when in the options for EMX 15 it seems to still be referencing the EMX 14 configurations and settings.
Any thoughts on how to fix this?
Mahesh_Sharma
22-Sapphire I
Hi @ST_3926557
You may try setting separate working directories for both of the versions and have respective config file in appropriate version folder.
Thanks.
