3-Newcomer
enable lmremove only for non-admins
is there an option to allow non Admins to use ptcflush/lmremove only on a Windows based FLEXlm server?
but not lmdown or so?
adminOnly yes, enables all these features, afaik.
br Bernhard
br Bernhard
read https://www.ptc.com/en/support/article/CS31332 document ...
  • For FLEXNet Admin License Server version 11.10.1
    • Stop the license server
    • Go to the installation directory of FLEXNet Admin License Server 11.10.1
    • Go to the “conf” folder and open “server.xml” in WordPad
    • Make the changes in the server.xml file as per a following example:
      <licenseServer adminOnly="true" .................... licenseReclaimAllowed="false"
                                                         -- To --
      <licenseServer adminOnly="false" ................... licenseReclaimAllowed="true"
    • Start the license server
bmüller3-NewcomerAuthor
3-Newcomer
Hi Martin,
thanks, but will this allow only lmremove/ptcflush and not lmstop,....?
br Bernhard
