Error 0x06000012 Quality Agent
when I start Creo parametric 3.0 (M110) the error code 0x06000012 appears and Creo shuts down.
I work with Windows 10.
I hope somebody's got an idea solving the problem.
18-Opal
June 12, 2017
Hi Sebastian,
Please take a look at the following bulletin from the PTC website:
Windows 10 Creators Update (1703) may cause blue screen system shut down with Creo Parametric 3.0
Amit
Hi Amit,
thanks for the answer.
I'm using the stundent edition, so my account is not authorized to follow the link.
Should I uninstall the Creators Update 1703?
Sebastian,
This solution in PDF format can be found in the attachment.
Related links:
