Error : "License is lost"
Frequently I am getting error like " License is lost " while working on CREO PARAMETRIC
Is there anyone facing similar issue. Please help me to resolve the problem.
the problem is related to your network communication. I do not have a simple advice how to resolve it. You can ask your IT department to check network traffic between your workstation and license server.
Martin Hanak
Martin ,
I have check with my IT team they said there is no problem with the connectivity .
Is there any chance of getting this issue because of using wildfire 4.0 ?
Manikandan
I am sorry, I don't know.
Martin Hanak
Manikandan periyasamy wrote:
Martin ,
Manikandan
Manikandan,
Were you able to work with your IT department to resolve the problem?
I have the problem when putting the computer to sleep. I downgraded the license manager and it helped, but did not completely solve the issue.
Now I know how to force the license server to stop and restart with the task manager.
2-Explorer
February 18, 2015
You can probably create an AutoIt program to do the entire thing automatically from a single button.
For those with a network license server, I suppose AutoIt could even be set to alert by running lmstatus/ptcstatus or whatever it is now and seeing when that drops or ping the server to see if the round-trip time is getting too long.
David,
Could pls explain how to set Autolt . hopefully it will help .
Manikandan
I face this often when using web based LM. If you are using LM tools check for right date code.
