Sep 22, 2015 12:44 PM UTC
Exists a methode to use Creo View if no internet and company vpn connection is available, e.g. an offline license?
Thanks and regards,
MK
2-Explorer
Sep 22, 2015 12:47 PM UTC
Creo View Express is still a free download. It has much more functionality than it did years ago. Very similar to Creo View Lite.
PTC Creo View Express | Free Download | PTC
knauthm1-VisitorAuthor
Sep 22, 2015 1:03 PM UTC
Creo View Lite has restrictions and therefore we use the editions Creo View MCAD, Creo View ECAD or Creo View MCAD and ECAD and a license server is necessary. Is there a possibility to use the MCAD and/or ECAD edition if the license server is via internet not available or the vpn connection to the company is not possible?
2-Explorer
Sep 22, 2015 5:21 PM UTC
If you have license borrowing set up you can do that. It works the same way as it does with Creo Parametric. The borrow command is in the Creo View loadpoint at <LOADPOINT>\bin\pvlicense_borrow.exe. Run this while you're connected to your license server. Choose the number of days to check out a license. You cannot return the license earlier than the number of days chosen however.
