Failed upgrade of CREO Parametric, 11.0.4.0 to 11.0.6.0
I have a failed upgrade of CREO Parametric, 11.0.4.0 to 11.0.6.0, that I am struggling with. The error message is ERROR: Unable To Launch Application Because No Valid Configuration File (*.psf) Files Were Found. Articles from the Knowledgebase state to run "reconfigure.exe" from the C:\Program Files\PTC\Creo 11.0.6.0\Parametric\bin folder, but the only "reconfigure.exe" that exists is in the C:\Program Files\PTC\FLEXnet Admin License Server\bin folder and does nothing but see the available license server when run. Any help would be greatly appreciated.
from my point of view upgrade of CREO Parametric from 11.0.4.0 to 11.0.6.0 includes following steps:
  • uninstallation of 11.0.4.0
  • installation of 11.0.6.0 (including defining the start command in the psf file)
