3-Newcomer
False model check error
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Creo Parametric are you currently running? Creo 7
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video. I am getting a false model check error after model check didn't find anything in Creo model.
4. What is the use case for your organization? yes Capgemini/Caterpillar
5. What business value would your suggestion represent for your organization?
What issue are you having with ModelCheck?
What version of Creo 7 are you running? There are issues with builds prior to 7.0.7.0 with ModelCheck.
Please detail the error messages and provide screen shots, if possible.
This is not a Creo Idea and you don't need that form to state your issue.
