Sep 23, 2011 7:44 PM UTC
Family table instances become standalone parts when saved during assembly use
When using family table instances within an assembly, the assembly requires that the instance be checked out in order to perform a save. The instance is somehow being modified, perhaps by dependencies, or otherwise. Once the instance is checked out, and the assembly is saved, the instance is no longer a part of the family table, and becomes a stand alone part. This is causing major issues with family table versions if the instance then gets checked in.
I have created a video to demonstrate what is happening as an example: http://communities.ptc.com/videos/2206
The S741.prt instance disconnects itself from the family table when the assembly using the instance is saved. During the example I've only done an edit definition, without changing anything, in order to save the assembly. I cannot figure out why the behavior to modify any of the parts used in the assembly is happening, as nothing has changed.
Both S740.prt and S741.prt are a part of the family table generic VOS_BODY.prt. I am able to checkout the VOS_BODY.prt and instances and make changes without the instance becoming Standalone. The instance remains intact to the family table. However, when checking out the instance required for the assembly operation, this is when the instance becomes Standalone
Has anybody else run across this at all? We are using Wildfire 4.0 M200 and Windchill 9.0 M050.
Thanks!
SeanSullAnswer
Oct 27, 2011 4:11 PM UTC
For anyone who is interested, I have resolved this issue by digging into our configuration files. It is only a band-aid fix, as the behavior or unlinking family table instances could prove to be fatal to family table files.
Our config.sup file had the following detail included:
save_instance_accelerator ALWAYS
By dialing down into this and removing it from the config.sup, the family table problem went away. However, I believe this to be a software bug, and have submitted it to PTC as such.
So heads up for anyone that might be wanting to use instance accelerators!!
SeanSull1-VisitorAuthorAnswer
Patriot_1776
Nov 4, 2011 3:33 PM UTC
Interesting. We don't use it, but that's good to know. Thanks! Hope they fix it!
