Fatal error on part creation while uploading another part
I am using Creo Parametric Release 7.0 and Datecode7.0.8.0
I experienced something weird with Creo 7.0.8.0 and Windchill 12.0.2.1 :
When I save and upload a CAD, if I am quick enough to create a new part while the upload is running, Creo crashes with a fatal error.
This problem is easily reproducible (only need to be fast).
Any idea what is the cause of this issue? Is there any way to tell Creo and/or Windchill not to start a download (in this case, the startpart) while another server operation is running (in this cas uploading a CAD)
Thank you in advance
achirilaAnswer
Emeritus
The solution to this post can be found here.
StephenW
Seems like you choose the wrong option and posted this back to the community
Yes it seems, my bad...
achirilaEmeritusAnswer
Emeritus
