Fichier de nomenclature .bom
I am using Creo Parametric Release 12.4 and Datecode12.4.2.0
We are encountering a problem when creating the .bom file. The .bom file is created, but it is limited to 2-3 characters, whereas we need more characters in this .bom file. We would like to avoid having to modify it manually each time, but rather have it allow more basic characters. Is there a configuration that allows us to do this?
Thank you in advance,
Best regards,
the description of the problem is completely inadequate. Please provide more details, attach pictures, upload Creo files packed into zip file.
Here is some more information:
In the image, you can see the two highlighted lines in the first column.
The latter only has five characters. Normally, the name should be “EQ_DIFF_VRT” or “EQ_DIFF_HRZ” (more than five characters).
How is it possible to enter more than five characters ?
please read following help page
https://support.ptc.com/help/creo/creo_pma/r12/usascii/#page/fundamentals/fundamentals/about_the_userdefined_bom_output_format_file.html
This page explains how to format BOM output.
