Jun 18, 2015 2:56 PM UTC
File, Manage Session freezes Creo 3 Parametric M040
Has anyone been experiencing this scenario:
Creo 3 M040
PDMLink 10.2 M020
Basic functionality File, Manage Session locks up Creo Parametric and user has to kill xtop.exe with Task Manager in order to exit. This functionality is needed since Creo forces users into Offline Mode. This is the only way to get back online.
Lance
TomU
Jun 18, 2015 3:33 PM UTC
We are currently in the same configuration (w/CPS09) and have not experienced this issue at all.  Have you tried a clean install w/no configs?  What about enabling Creo WGM debugging?
llie17-PeridotAuthor
Jun 23, 2015 5:58 PM UTC
Tom,
Can you reproduce these steps and get Creo back online. We all know that Creo kicks/forces users offline once in a while.
With Creo linked to PDMLink:
1. In  Creo, select File, Manage Session, Server Manager, RMB on your active server, select Work Offline, Close Creo Parametric, kill all of the processes.
2. Open Creo, select File, Manage Session, Server Manager, RMB on your active server, unselect Work Offline, select OK from the Synchronize Workspaces Window.
Creo freezes on any of the following: selecting Server Manager, RMB on your active server, unselecting Work Offline, or selecting OK from the Synchronize Workspaces Window
Please let me know what happens.
TomU
Jun 23, 2015 6:13 PM UTC
No issue.  I can't make it fail.  Two points.
  1. Generally when going offline or online, I uncheck upload and download and only allow it to synchronize.  (Leaving everything enabled didn't make any difference.)
  2. I have the embedded browser set to Chromium.  I did not test this functionality with Creo configured to use Internet Explorer.
