File name length limit STILL 31 characters!!!
Please PTC, please remove this ridiculous limit... it's 2017 for God's sake....
    StephenW
    Long requested... Remove the limit of 31 characters in creo file name If you have maintenance, you can vote on the product enhancement request.
    This has been in the planning for a long time with no implementation in sight.
    Duplicate request/complaint!
    How many PTC programmers does it take to fix the length of the name field?
    32, but only 31 work.
    I appreciate the replies... I know this is a duplicate complaint.  I just needed to rant about it since, at the moment, it's interfering with my job, once again.
    2-Explorer
    <rant>
    With 26 alphabetic characters, 10 digits, and the underscore you have only 37^31 possible names or 4113897303606771042156868599311296618503721408813.
    Did you run out?
    It's an easy limit to hit when making filenames into encyclopedia entries covering revision history and routing and material and who worked on it and what the release level is and so many other non-name factors.
    The good news is they are apparently going to increase the limit, but I shudder to think of looking into a model tree with part names of 512 characters, or maybe 1024 just to be sure.
    </rant>
    Hi dschenken,
    Yes, I ran out.....I got to part number 4113897303606771042156868599311296618503721408814 and had an error.
    I know you're trying your best to belittle me or others who might have issue with the limit, but there just might be other issues that you haven't considered.
    No, I (we) don't use such long filenames for parts or assemblies we create for our database at my job.  I think such long filenames are silly, too.
    However, as you may or may not know, dealing with customer CAD many times requires much longer filenames.  Having to truncate them to be friendly with our database is often time consuming, and shouldn't be necessary at all... hence my original rant/complaint.
    Here is an example part number from an automotive manufacturer I deal with (yes, underscores, and all):
    561_807_305____OUT_TM__011_000_ZSB_QUERTRAEGER_HI_22032010____________
    Imagine hundreds of these part numbers for a larger assembly.... maybe now, you understand.
    A 31 character filename limit is ridiculous.  Yes, this is a repeat complaint, but it's still not fixed in the latest version of Creo...unacceptable.
    2-Explorer
    bsingleton,
    It's hardly belittling to point out the lack of need for a feature, though perhaps your customer should feel ashamed of encoding a good portion of their process management into plain text. 22032010 looks like a day-month-year, for example. could be reduced to 3 ascii characters instead of 8. Dashes could be used to terminate fields so that empty "_"'s were not required to align fields.
    I can't fix Windchill, Creo, or your customer, so don't belittle me for expressing my own clearly marked not-all-about-you rant
    I can suggest that in order to handle your customer, you use a hash function on the original name. This will reduce the lengthy name to any number of characters, and 31 will be plenty. To decrease the odds of collision, add a random number to the customer number that is generated with the date field as the seed value so it will be repeatable. The original name can be stored as a parameter that is declared to Windchill, if you like, so that Search can find ir. By using a hash with a seed, it isn't absolutely required to keep a table of all the conversions; any component file that is opened can be inspected for the original number and any request by customer number can have the hash generated to find the component hash number.
    I wholeheartedly concur...
    This functional change could hardly be called an enhancement or improvement... it's an essential necessity. This "CREO IDEA" is over 5 years old.  While some creo uses don't find the file name length a hindrance, many of us have a need to identify parts, assemblies, and drawings with sensible and practical names.  While this is a testament to the variety of uses of creo, the length of file names should not be a limitation to those of us who would benefit by this capability.  15 years ago, 31 characters was enough to discern between parts and assemblies developed for a few clients.  Now, with thousands of clients, and hundreds of thousands of distinct parts that would more easily be understood with meaningful file names, this has become a limitation of productivity and profitability, especially while trying to compete with other growing contemporary CAD providers.
    It is obvious, from the Replies, that CREO is used in a vast variety of implementations.  Not everybody needs the capability to use long, or even descriptive filenames for CREO files... but a great many do.  And just because a computer file name could be 255 characters long (there are other limitations - because of file path), doesn't mean that the use of the longest file name possible is practical, or sensible.  Anybody who wants to could still use the default short incremental file names... just please give me the contemporary tool of sufficiently long file names (maybe 50 or 55 characters would suffice for the next 10 years or so - and still leave 200 characters for the path), so that I can be descriptive when I have the need.  There are occasions when sufficiently descriptive file names simply makes it easier to be productive, and competitive.  If it wasn't for descriptive names, msn.com would still have to be identified by 13.82.28.61 (yes - there are already website names that exceed 31 characters and are reasonably descriptive - look it up).  And I still name files in my documents directory something meaningful to me, even though I don't have 10,000 files in there.
    I dug this one up while confirming the file name length and writing a batch script to rename some 600 files imported from SolidWorx.  Yay, fun times.
    18-Opal
    At minimum for Legacy purposes, and for things like emails stored in WC, the length should not be limited (WC should just match Windows and other supported OSs), because when you are importing something it increases the likeliness of a poorly thought out migration where users are forced to truncate the file names and essentially lose information that was stored in the file name for many years prior to migrating to WC.
    @bsingleton and all others reading, do yourselves and your customers a favor and do the following:
    • Migrate the long filename as another field (name, description, or better yet create a non-required field/attribute such as Legacy_filename)
    • Get your company to decide on a standard naming scheme for the filename/number meaningful and not random (smart sequential is better), and then use that going forward.
    • Get your company to use your company created attributes, or create some, to capture essential information that you would want to search by later (e.g. product name, category, etc).
    • Update your standard.
    This way you might actually be able to narrow your search when trying to find the right document later.  This is advise that I wish we received and followed during a past migration because it would have put us in a much better place now...rather than doing a search and getting a hundred files that no longer have a descriptive name and you have to open them all to find the right one...every time you do a search!
    Little pain upfront, but a lot less pain and much more benefit later on (read: increased productivity & reduced user frustration).
    Hopefully for you this will not be great advise too late (like Mom yelling "careful" after she hears you get hurt...or the kaboom! Smiley Happy )
    2023 and still counting.
    2024 and still super annoyed...
    Finally we have at least a target for the fix of this problem, Creo 12!
    https://community.ptc.com/t5/Creo-Parametric-Ideas/Remove-the-limit-of-31-characters-in-creo-file-name/idc-p/914840/highlight/true#M20042
    So possibly around 15 years from product idea to implementation for a thing that has not been a problem in any other program for decades, that's nice.
