Jan 25, 2013 10:09 AM UTC
File saving problem
Now-a-days I am facing a new problem in creo 2, when I am saving any file from the menu bar file> save> then rapidly pressing mid button, its not saving at all. By clicking ok button its perfectly saving. As far as I can remember i always used to save by rapidly pressing mid button after file>save in previous version. Have anyone came across such kind of situation?
Jan 25, 2013 10:13 AM UTC
it is still getting saved by pressing middle button...i am using CREO 2.0 M010. hope your mouse is not an issue?
Jan 25, 2013 10:16 AM UTC
It should make no difference whether you click the middle mouse button rapidly or slowly - MMB for "Done" or "OK" should work for most functions in Pro/E, including File->Save and File->Open.
Sometimes I try to use this for File->Open in other applications - then it doesn't work!
jsarkar1-VisitorAuthor
Jan 25, 2013 10:33 AM UTC
My mouse does not have any issue, however some intralink options are set. I suspect may be because of those options. Seems like i need to investigate little more. Anyway thanks for reply.
Dale_Rosema
Jan 25, 2013 2:27 PM UTC
Sorry about that. I'm an old school. Alt-F, S, slap the space bar with your thumb guy - - give that a try. But I know that we each have our ways.
