Find file inside CREO
I need to find this file inside creo , I've searched and all the PTC folder , but it doesn't find anything pmech_conn.TXT
KenFarley
KenFarleyAnswer
If you search for this in your browser you will likely get something like this:
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/simulate/mech_des/About_Diagnosing_Failures_in_Mechanism.html
It states that the file referenced is created (in your current working directory) in response to some sort of error. Hopefully that is where you will find it. Pro/ENGINEER and now Creo likes to write errors into weird named files like this. Hopefully if you find it you will have some useful information about what is wrong.
KenFarley
KenFarley21-Topaz IIAnswer
