FlexNet Admin License Server
I had a problem on the server , I had to remove the FlexNet Admin License Server , even more so in C:\Program Files\PTC and in the services too , I need to install it again and I am not succeeding , would there be a way to remove it and install it again , or install over?
MarcoTosin
Did you do a server reboot after reinstalling the license server?
Without the reboot, you will never see the service working, even if you start it manually.
To remove the service you can run from the command prompt the command
sc delete servicename
https://learn.microsoft.com/en-us/windows-server/administration/windows-commands/sc-delete
Marco
MarcoTosin
Marco
1.] What installation package do you use for reinstallation ?
2.] Please provide more details concerning reinstallation (pictures, error messages). Look into Event Viewer, too.
