Feb 25, 2010 11:13 PM UTC
Floating license on the Internet
I have a floating license of Pro/e and would like to be able to access it remotely over the internet. The server machine is behind a firewall, so I know that changes will need to be made there. What will the host setting look like on the client?
Mar 3, 2010 2:43 PM UTC
Hi Bob, I have the same issue / desire. I have no sugguestions, but am hoping perhaps you have figured it out allready? Would love to know how to do this. Good luck gregory
Mar 5, 2010 6:29 PM UTC
It can be done using VPN. Consult with you IT dept.
3-Newcomer
May 11, 2010 7:46 PM UTC
I've got a similar setup to the original poster; I'm trying to run Wildfire 5 floating license outside my company's network on my personal notebook. The license server is in-house, however, and behind a SonicWall firewall. When I try to fire up Wildfire while at home through a VPN tunnel, I get an error saying I can't see the license server. My problem seems to be with the firewall configuration, or the VPN tunnel, because if my notebook is plugged in to the wall of my office I don't get an error finding the license server. I've opened up the 7788 port on the SonicWall to my license server in-house, but I don't know what else to open on it. I'm kinda lost. Help?
7-Bedrock
May 19, 2010 10:20 PM UTC
This is quite easy and no VPN required.
Open ports 7788-7799, this is the licensing port. You may edit the ptc.opt file to include the port number 7788 added to the end of the DAEMON line.
Wildfire 5 went weird a bit, but in your config.pro or your config.sup you will have to add a hidden config option to disable triad license server. I'll have to dig through a couple of emails to find this option. I'll update the post when I have this. Or, if you contact support you can get it as well.
