Dec 5, 2015 3:07 AM UTC
Getting Error dialog on object check in.
User are getting this error on checking in an object to the vault.
System Info:
Pro/Engineer Wildfire 3.0 running on Oracle 9.2.0.5 DB and (ahem!) Windows Server 2000.
We just recovered the database from a crash and this behavior occurs.
I have been in this position for five weeks, so no snarky comments about the environment .  I am working on modernizing it, but first...
Anyway, I will be trolling through the logs this weekend to see if a clue pops up.
wgalanisAnswer
Dec 7, 2015 7:17 PM UTC
OK, solved the issue with my very competent DBA.
Solution to Pro/Engineering issue:
Error at USER end:
Message: ToolKit Error : -4068
Arguments:    0:
ORA-04068: existing state of packages has been discarded
ORA-04063: package body "PDM.PDMSP_TXNMODE_PKG" has errors
ORA-06508: PL/SQL: could not find program unit being called
ORA-06512: at line 1
On server side (SQLPlus):
select owner, object_name, object_type, status from dba_objects where owner = ‘PDM’ and object_name = ‘PDMSP_TXNMODE_PKG’;
OUTPUT:
OWNER  OBJECT_NAME          OBJECT_TYPE  STATUS
PDM    PDMSP_TXNMODE_PKG    PACKAGE      VALID
PDM    PDMSP_TXNMODE_PKG    PACKAGE BODY  INVALID
SQL> set serveroutput on;
SQL> alter package PDM.PDMSP_TXNMODE_PKG compile body;
Warning: Package Body altered with compilation errors.
SQL> show errors;
Errors for PACKAGE BODY PDM.PDMSP_TXNMODE_PKG:
LINE/COL ERROR
71/9    PL/SQL: SQL Statement ignored
72/14    PL/SQL: ORA-00942: table or view does not exist
133/17  PLS-00201: identifier 'DBMS_LOCK' must be declared
133/17  PL/SQL: Statement ignored
Oops, have to do more stuff:
SQL> grant execute on DBMS_LOCK to PDM;
Grant succeeded.
SQL> show errors;
LINE/COL ERROR
Getting Closer, another step
More changes:
SQL> grant select any dictionary to PDM;
SQL> grant select any table to PDM;
SQL> show errors;
No errors.
Yes!
Validating:
SQL> select owner, object_name, object_type, status from dba_objects where owner = 'PDM' and object_name = 'PDMSP_TXNMODE_PKG';
PDM                            PDMSP_TXNMODE_PKG    PACKAGE BODY      VALID
Now, check for more surprises:
SQL> exec dbms_utility.compile_schema('PDM',FALSE);
PL/SQL procedure successfully completed.
SQL> select count(*) from dba_objects where owner = 'PDM' and status = 'INVALID';
  COUNT(*)
        0
All done and users can check in drawings.
wgalanis1-VisitorAuthor
Dec 7, 2015 5:09 PM UTC
More information from the user's logs:
Error Stack:
Error 0:
Message: This error message has internal usage only.
It should be never put into stack.
Please check the online knowledge database at www.ptc.com
and/or contact Technical Support,
Arguments:
Error 1:
Arguments:
Error 2:
Arguments:
Error 3:
Arguments:
    0: ORA-04068: existing state of packages has been discarded
wgalanis1-VisitorAuthorAnswer
Error at USER end:
Arguments:    0:
OUTPUT:
SQL> show errors;
LINE/COL ERROR
Grant succeeded.
SQL> show errors;
LINE/COL ERROR
More changes:
SQL> show errors;
No errors.
Yes!
Validating:
  COUNT(*)
        0
