Mar 23, 2014 1:52 PM UTC
getting started - viewport question
Everything in the viewport disappears when I start a new action. I have to move the view (pan, zoom, or etc.) to see anything again. Is this a settings issue or a computer issue? I have been using CoCreate at work for many years, I just loaded this free version on to my personal computer.
Mar 23, 2014 6:34 PM UTC
I am not sure I undertand you question, Julie. Basic Creo Parametric does not have view ports. It simply has a graphics window (unless you have the style option).
When starting a new part, the default datums planes can be huge. Once a feature is created, these scale to the extent of the bounding box, which is the size constrained by the newly created physical geometry.
Feel free to show some images or even a video of the problem you are having.
Mar 23, 2014 7:12 PM UTC
Thanks for responding. I made a quick video with my camcorder. In the video I draw a rectangle and extrude a box, then draw some more lines on the workplane. The view/window keeps going blank, or only showing what my cursor is directly hitting.
https://www.youtube.com/watch?v=KX6ACIlcs40&feature=youtu.be
Mar 23, 2014 9:53 PM UTC
Thanks, that helps.
Unfortunately this is Creo Elements direct so it is quite different than I was thinking.
It seems the spin center is not in an optimal location. Also, you may be having graphics driver issues during sketching.
I know very little about Creo Elements direct. I am not sure how to get support from PTC for this application.
