Feb 21, 2017 3:46 PM UTC
Hello:
While installing Creo 3.0, the PTC Installation Assistant continually freezes. Any thoughts?
Thanks!
Feb 21, 2017 4:52 PM UTC
Make sure your Right Mouse Click the setup.exe file and choose "Run as Administrator". In my experience it doesn't install everything correctly unless you do.
lbeman1-VisitorAuthor
Feb 21, 2017 6:10 PM UTC
I tried that to no avail. I did find out that I can install using the regular setup.exe rather than the setup-schools.exe, it's just a bit more cumbersome.
Len
Feb 21, 2017 5:02 PM UTC
please confirm that you executed following steps:
1.] you downloaded 4 GB zip file from PTC containing installation medium
2.] you unzipped zip file into new directory (what software did you use for unzipping ?)
3.] you launched setup.exe from directory mentioned in step 2.
MH
Feb 21, 2017 6:09 PM UTC
We aren't server based, we have stand alone licenses for each machine. What I've found I can do is use the standard setup rather than the setup-schools.exe. It's a bit more cumbersome, but it all works out in the end. I've also installed 3.0 on four other machines without incident, so perhaps there is something glitchy with the particular machine I am using.
Len
Feb 22, 2017 4:22 PM UTC
if PTC Installation Assistant continually freezes, you can try this trick ... create new administrator account, log in and run installation.
MH
